2950 switch showing Switch: prompt
I have deleted nvram file system and reloaded the switch.
switch is showing following message:
Switch#erase nv
Switch#erase nvram: ?
<cr>
Switch#erase nvram:
Erasing the nvram filesystem will remove all configuration files! Continue? [con
firm]
[OK]
Erase of nvram: complete
Switch#
05:27:50: %SYS-7-NV_BLOCK_INIT: Initalized the geometry of nvram
Switch#reload
Proceed with reload? [confirm]
05:27:55: %SYS-5-RELOAD: Reload requested
C2950 Boot Loader (C2950-HBOOT-M) Version 12.1(11r)EA1, RELEASE SOFTWARE (fc1)
Compiled Mon 22-Jul-02 17:18 by antonino
WS-C2950G-48-EI starting...
Base ethernet MAC Address: 00:14:69:dd:cd:80
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 0 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 1024
flashfs[0]: Bytes available: 7740416
flashfs[0]: flashfs fsck took 4 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading ""...: permission denied
Error loading ""
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
switch:
switch: ?
? -- Present list of available commands
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
load_helper -- Load and initialize a helper image
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_param -- Set system parameters in flash
trap -- Cause a software breakpoint to occur
type -- Concatenate (type) file(s)
-- MORE --
unset -- Unset one or more environment variables
version -- Display boot loader version
switch: lo
switch: reset
Are you sure you want to reset the system (y/n)?y
System resetting...
Error loading ""
image.
switch:
How to set the boot environment variables?
Required your suggestions.......
SKRAO
Hall of Fame Super Bronze
Re: 2950 switch showing Switch: prompt
sivakondalarao:
"The system is unable to boot automatically. The BOOT
image. "
It seems your configuration file contains a reference to a boot image that no longer exist.
I recommend trying the following:
#rename flash:config.text flash:config.old
#boot
>enable
#rename flash:config.old flash:config.text
#copy flash:config.text system:running-config
#dir flash:
Write down the IOS image
#show run
replace the boot system variable to match the IOS image listed in the flash folder.
The switch is not having any IOS image files in the flash! [flashfs[0]: 0 files, 1 directories ] Or maybe you have one in the directory that you have there.
You need to copy an IOS image into the flash, so that you switch can boot with it! Copy a file into the flash and boot with it.
Have a look at the following link:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_example09186a0080169627.shtml
Hope this helps!
AbhisheK
Please rate all helpful posts!!!
SKRAO,
See the reason for the error below. Appears, you mayn't have a valid IOS and you can copy a valid image using xmodem function.
Getting "Error Loading Flash" error messages.
The error loading Flash message means that there is a problem loading the current image in Flash memory. The image could be corrupt or incorrect, or the image in Flash memory could be missing. If the system is unable to load a software image in Flash memory, the system will load the boot helper and bring up a switch prompt.
1. Enter the dir flash: command to verify if there is any bootable image on the Flash memory. The file with the .bin extension is the bootable image on the Flash memory.
If you see a bootable image on the Flash memory, continue to Step 2. If you do not see any bootable image in the Flash memory, download the IOS Image File by using X-Modem.
2. Enter the set BOOT flash: name of IOS file command to set the boot variable to the filename displayed in Step 1.
Note BOOT must be capitalized and make sure to include flash: before the filename.
3. Enter the boot command.
Note If the switch boots properly, enter the setting boot parameters global configuration command to verify and set the BOOT parameters (if needed), and proceed to Step 4. If the switch fails to boot properly, download the IOS Image File by using X-Modem.
4. After setting the BOOT parameters, reload the switch by entering the reload privileged EXEC command.
The switch boots up automatically with the correct image.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a008007e923.html#xtocid273064
HTH,
Sundar
3212
