2950 VLAN Problem
dunn
I have a 2950 that is running the same configuration as three other 2950s in my data center. All are running the same IOS, 12.1(9)EA1. This switch does not seem to be learning the management VLAN that I have created for all of my cisco devices. The configuration running on this switch is similar to this config, with a different hostname and VLAN2 IP address. I am unable to remotely manage this device or ping it by the IP address that is assigned to VLAN2. There is communication over the trunk port though, and I am able to connect devices to this switch and they connect to my network without any issues. Any idea how I can resolve this? please let me know if I can provide any additional information. Thanks.
Current configuration : 3356 bytes
version 12.1
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname cisco2950DC3
logging buffered 10000 debugging
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport access vlan 100
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/24
interface GigabitEthernet0/1
description Trunk to 3550
switchport mode trunk
interface GigabitEthernet0/2
description Trunk to cisco2950dc4
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan2
ip address 10.1.2.24 255.255.254.0
no ip route-cache
ip default-gateway 10.1.2.1
ip http server
logging trap debugging
logging 192.168.1.10
snmp-server engineID local xxx
line con 0
login local
stopbits 1
line vty 0 4
exec-timeout 15 0
login local
line vty 5 15
exec-timeout 15 0
login
monitor session 1 source interface Fa0/1 - 23 rx
monitor session 1 destination interface Fa0/24
end
17 Replies 17
froggy3132000
Level 3
Level 3
So what you are saying is certain vlan's are not being propagated to this switch?
Can you print the output of "show vtp status"?
gpulos
Level 8
Level 8
the G0/2 interface shown above does not have a trunk defined. (although it states in the description it is a trunk)
you'll need a trunk to the 2950 if it's connected to G0/2 in order to get vtp updates across that link.
glen.grant
Verify the trunk is working correctly, "show int trunk" . Are you running client server or transparent . If just running transparent I don't see where you created the layer 2 vlan for vlan 2 which should show up in the config if running transparent . Verify with the show vlan command and see if vlan 2 is created and in a active state , if not just do a conf t , vlan 2 , enter and recheck and see if you can get to the switch after about 35 seconds.
John Burnham
Which port is connected to the rest of your network?
Upgrade to 12.1(22)EA8.
Run "show vlan"? VLAN 2 may not be set-up on the switch. I have seen VLAN's not coming up if you do not specify VLAN ID in an interface.
If you want your switches to update each other for VLAN you need to create a VTP domain, otherwise to be safe use VTP transparent to avoid a test switch crashing your network.
I ran a few of the diagnostic commands that were suggested, the results are listed below. I have also included the config from the switch that I cannot remotely manage. The config that I previously included was from a similar switch in my data center. G0/1 is connected by a crossover cable to G0/2 on the other switch. The other switch port that it connects to does not have switchport mode trunk set on the port. I have tried adding this and I lose all connection to the switch on the other side.
sh int
Vlan1 is administratively down, line protocol is down
Hardware is CPU Interface, address is 000f.90c2.e1c0 (bia 000f.90c2.e1c0)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 4000 bits/sec, 8 packets/sec
18955503 packets input, 1366709181 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicast)
20585097 packets output, 0 bytes, 0 underruns
0 output errors, 2 interface resets
Vlan2 is down, line protocol is down
Description: Managment VLAN
Internet address is 10.1.2.25/23
0 packets input, 0 bytes, 0 no buffer
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 interface resets
sh vtp stat
VTP Version : 2
Configuration Revision : 5
Maximum VLANs supported locally : 250
Number of existing VLANs : 8
VTP Operating Mode : Client
VTP Domain Name : hlvtp
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x25 0x8D 0x94 0x90 0x1F 0x33 0xE3 0xD7
Configuration last modified by 192.168.1.190 at 3-2-93 07:22:28
cisco2950dc4#sh int trunk
Port Mode Encapsulation Status Native vlan
Gi0/1 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi0/1 1-2,100-110,200-205,1002-1005
Port Vlans allowed and active in management domain
Gi0/1 1,100-101
Port Vlans in spanning tree forwarding state and not pruned
Gi0/1 1,100-101
cisco2950dc4(config)#vlan 2
VTP VLAN configuration not allowed when device is in CLIENT mode.
Here is the config:
cisco2950dc4#sh run
Building configuration...
Current configuration : 4629 bytes
version 12.1
no service pad
hostname cisco2950dc4
ip subnet-zero
no ip address
description IDS Monitor
no ip address
switchport trunk allowed vlan 1,2,100-110,200-205,1002-1005
no ip address
no ip address
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan2
description Managment VLAN
ip address 10.1.2.25 255.255.254.0
no ip route-cache
no ip http server
logging 192.168.1.118
snmp-server engineID local 000000090200000820FD0000
line con 0
login local
stopbits 1
line vty 0 4
exec-timeout 15 0
login local
line vty 5 15
exec-timeout 15 0
login
end
Being in the client mode, this switch should get vlan info from server. But ur diag results shows that the particular vlan is in down state. It looks like that this switch not getting info for vlan 2.
Pls.see the show vlan command result that whether the vlan 2 shows active or not and also check the connected port of neighboring switch whether they are passing vlan 2 to this switch or not.
Rate if it does,
Rgs
Make sure vlan 2 is defined and being allowed across trunk on the far end . Also make sure vtp domain name matches exactly on all your switches...
The switch which is configured as VTP server mode must include VLAN2. However, if you want to have a quick test. You can try to remove the VLAN2 IP address and add it back to VLAN1 to determine the connectivity. If it works, it is VTP mode issue. If it isn't there may be another issue.
I have about 10 devices connected to this switch. Is this a safe change to make during business hours?
Here is the show vlan. VLAN 2 is not showing up, so it is doesn;t look like it is being learned from the connected switch. How can I fix this?
VLAN Name Status Ports
1 default active Gi0/2
5 VLAN0005 active
100 VLAN0100 active Fa0/1, Fa0/2, Fa0/3, Fa0/4
Fa0/5, Fa0/6, Fa0/7, Fa0/8
Fa0/9, Fa0/10, Fa0/11, Fa0/12
Fa0/13, Fa0/14, Fa0/15, Fa0/16
Fa0/17, Fa0/18, Fa0/19, Fa0/20
Fa0/21, Fa0/22, Fa0/23, Fa0/24
101 VLAN0101 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
5 enet 100005 1500 - - - - - 0 0
100 enet 100100 1500 - - - - - 0 0
101 enet 100101 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
cisco2950dc4#
Please post the far end switch config , along with the "show vlAn", and sh int trunk command . Verify the far end is really running as a server adn not as transparent . Verify vtp domain names are the same . This should be a simple problem just need configs from both ends...
This is the config for the far end switch.
version 12.1
no service pad
ip subnet-zero
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan2
no ip route-cache
ip http server
line con 0
login local
stopbits 1
line vty 0 4
exec-timeout 15 0
login local
line vty 5 15
exec-timeout 15 0
login
end
Here are the diag commands from the far end 2950 switch. This 2950 is also configured as a VTP client. The only VTP server on my network is a 3550 that we have setup a the core.
cisco2950DC3#sh vlan
1 default active
2 LAN_Mgmt active
3 VLAN0003 active
10 VLAN0010 active
11 VLAN0011 active
101 VLAN0101 active
102 VLAN0102 active
103 VLAN0103 active
104 VLAN0104 active
110 VLAN0110 active
200 VLAN0200 active
2 enet 100002 1500 - - - - - 0 0
3 enet 100003 1500 - - - - - 0 0
10 enet 100010 1500 - - - - - 0 0
11 enet 100011 1500 - - - - - 0 0
102 enet 100102 1500 - - - - - 0 0
103 enet 100103 1500 - - - - - 0 0
104 enet 100104 1500 - - - - - 0 0
110 enet 100110 1500 - - - - - 0 0
200 enet 100200 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - srb 0 0
cisco2950DC3#sh int trunk
Gi0/2 desirable 802.1q trunking 1
Gi0/1 1-4094
Gi0/2 1-4094
Gi0/1 1-3,10-11,100-104,110,200
Gi0/2 1-3,10-11,100-104,110,200
cisco2950DC3#sh vtp status
VTP Version : 2
Configuration Revision : 4
Number of existing VLANs : 16
MD5 digest : 0x3B 0x4D 0x4D 0x4A 0x03 0xF5 0x15 0x9E
Configuration last modified by 10.1.2.1 at 8-14-94 04:35:44
