08-29-2002 05:25 AM - edited 03-02-2019 12:59 AM
CW2000 thinks my 2950G-48-EI switches are "ciscoProducts.429". The correct properties of a 2950G-48 are not recognised and we cannot manage the switch through CW2000. Latest device packages have been installed. Software is 12.1(6)EA2a and 12.1(9)EA1d. Any ideas anybody?
08-29-2002 09:16 AM
What version of RME and Campus Manager you have in your CW2K bundle?. It depends on that. 2950G-48 is only supported in RME 3.4 with RME34.IDU.v1-0 installed from CCO. Campus Manager 3.2 supports this switch as well.
08-30-2002 12:48 AM
Thanks for the reply. We are already running RME 3.4 and CM 3.2 both from 7-22-2002. What is RME34IDU.v1-0 and how do I get it?
08-30-2002 09:15 AM
IDU= Incremental Device Update and you can get it from:
09-02-2002 02:40 AM
Thanks. We opened a TAC and got the information from there. It works now.
08-30-2002 10:10 AM
Do you know if there is a way of getting RME3.3 and Campus Manager 3.1 to support them as well ?
Will the latest IDU or patch's do the trick ?
Thank you.
08-30-2002 10:34 AM
There is a RME 3.3 IDU v1-0 at: http://www.cisco.com/cgi-bin/tablebuild.pl/idu10 which suports 2950G-48
