2950g problem
We have a problem with configuration in the network of a customer. The problem is in a link between a 3200 Cisco Catalyst Switch and a 2950G Cisco Catalyst Switch. The link is a copper cable and both ports are in fixed configuration 100MHZ Full Duplex.
When we connect this switches , the port in the 2950G is in the forwarding state but the port in the 3200 go to the listening state and after go to the learning state. The port in the 3200 switch only is in these states (learning and listening) but never goes to the forwarding or blocking states.
First we think that it was a spanning tree problem but when we have changed the 2950G switch by a 2950XL or 1950XL switch the network works right and all ports is forwarding.
We upgraded the 2950G catalyst software and all is the same.
We have checked the ports configuration and the port fast option is not enable in the ports.
There are no other problems in the network and spanning tree is working right.
Do you know this problem and then what is the solution?
  • Other Network Infrastructure Subjects
VIP Purple
Re: 2950g problem
can you post the config of the 3200 ?
GP
Re: 2950g problem
Apologies for the delay, I send the configuration.
Catalyst 3200 CHJ1
Cisco Catalyst Manager
(c) Copyright Cisco Systems, Inc., 1995-1996 - All rights reserved.
MAC Address: 00 80 24 67 A8 90
Switch Information
Return to Previous Menu
Number of Boxes 1 Stack State Not Operational
Local Box Number 1 Stack Connection Not Present
Remote Box Number(s) None
Stack Time-out (sec.) 16
System Description Cisco Catalyst System
System ID 1.3.6.1.4.1.9.5.15
System Name Catalyst 3200
System Location
System Contact
Time of Day... Tue. October 21, 2003 09:54:43
MAC Address 008024 67A890
Boot Description Boot Firmware (Phase II) v2.0
Interface Description Cisco Catalyst 3200 HW Rev 2
SW 2.2(8) (Feb 15 1999 12:13:07)
DRAM Installed 8 MB
FLASH Memory Installed 1024 KB
Enhanced Features Enabled
Port Duplex Control Hardware Ctrl
Port Configuration
Port Type Link MDI/MDIX Speed Mode Duplex Enabled/Disabled
1 ISL FX up 100 A-CT Full Enabled
3 ISL FX up 100 A-CT Full Enabled
5 ISL FX up 100 A-CT Full Enabled
7 ISL FX up 100 A-CT Full Enabled
9 ISL FX up 100 A-CT Full Enabled
11 ISL FX up 100 A-CT Full Enabled
13 ISL FX up 100 A-CT Full Enabled
15 ISL FX up 100 A-CT Full Enabled
17 10BaseT down MDIX 10 A-CT Half Enabled
18 10BaseT up MDIX 10 A-CT Half Enabled
19 10BaseT up MDIX 10 A-CT Half Enabled
20 10BaseT up MDIX 10 A-CT Half Enabled
21 ISL TX up MDIX 100 A-CT Full Enabled
23 ISL TX up MDIX 100 A-CT Full Enabled
25 ISL TX down MDIX 100 A-CT Full Enabled
27 ISL TX up MDIX 100 A-CT Full Enabled
Port Switching Mode
Port Switching Mode Error Water Mark Runt-free Mode
1 Auto 50% off
3 Auto 50% off
5 Auto 50% off
7 Auto 50% off
9 Auto 50% off
11 Auto 50% off
13 Auto 50% off
15 Auto 50% off
17 Auto 50% off
18 Auto 50% off
19 Auto 50% off
20 Auto 50% off
21 Auto 50% off
23 Auto 50% off
25 Auto 50% off
27 Auto 50% off
99
