Community Member
2nd FE Port for 2620
Is there a way to add a second 100 Mbps Fast Ethernet port to a Cisco 2620? This 2620 is already installed and in service.
Re: 2nd FE Port for 2620
You can add a NM-1FE2W module, which is a network module which can go in the empty slot on the left side of the 2620. This module has one fast ethernet port, and 2 additional wan card slots.
Community Member
My understanding is that the NM-1FE2W is not available for the 2620 series. This is based on trying to configure a 2620 with this network module in the Cisco Configuration Tool, which does not list the NM-1FE-2W (or other coonfigurable Network Modules) as an option for the 2620. Also, according to the Access Router Guide (.pdf document), this Network Module is not available for the 2620.
If my understanding is incorrect, please let me know. Otherwise, do I have any additional options?
338
