2nd Try - Trunking problem on 6500 switch
We have a setup where 6509 switch of Head office is connected to another 6506 switch in Branch office via RF link.
We have VLANs 10, 20, 30, 40 and 61 in HO. This branch office is an extension of the LAN in HO and has VLAN 30 and VLAN 61. This setup is working absolutely fine.
We planned to have a backup for this RF link. The service provider has given a G703 connectivity across these 2 locations. This G703 connection is terminated on RAD's HTU-E1 modem which has a G703 interface on one end and the other interface is connected directly to the 6500 switch.
When we disable the RF link and try to check the connectivity across this link then we have the following observations..
1) When we configure the port as a part of VLAN 30, then users in the branch office are able to access all the servers and other vlans in HO properly.
2) When we configure the port as a part of VLAN 61, then users in the branch office are able to access all the servers and other vlans in HO properly.
3) But when we configure this port as a trunk port, then only ping traffic goes across. No other traffic link DNS request, login authentication and so on goes across except ping.
Can any one advice me what could be the problem and any work arounds if possible.
Thanks in advance.
Jignesh
Re: 2nd Try - Trunking problem on 6500 switch
If you have other switches on your network such as 4000 series switches you will have to use dot1q.
For an example: set trunk mode on nonegotiate dot1q
Thanks for your reply.
The other switch is 6500 switch only. We have tried using both dot1q as well as ISL. The observation is the same. Only ping traffic goes across. Other traffic does not go across the link.
Jignesh
Purple
What is the status of the trunk , does everything look normal when you do a show trunk ? Do all your vlans show active across that trunk ?
If you can give me your email address, then I can mail you the output.
Jignesh
100
