07-27-2003 03:52 PM - edited 03-02-2019 09:09 AM
I have a 3661 router with a 16 port Analog Modem(33.6K speed) module . I want to replace the 33.6K speed with a 16 port analog modem(56K speed) module.
Is that possible ? Will I need to change any config or settings ?
08-01-2003 12:14 AM
If you're talking about the NM-16AM, the link below says it's not possible:
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_tech_note09186a00800a93f2.shtml#feat
HTH.
08-03-2003 01:59 PM
Thank you. I did have a look at that link. Does this mean that there is no analog modem module for 3661 router that can support up to 56K ?
08-03-2003 11:57 PM
There's the wic-1AM and wic-2AM that support V.90 client mode (i.e. 56k when dialing to a V.90 server modem) so they are still limited to 33.6 for dial-in use. And obviously they provide a much lower port density and require a network module that supports wic's.
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_tech_note09186a00800ad45b.shtml
hth
Herbert
