04-30-2002 10:32 PM - edited 03-01-2019 09:33 PM
I'm having problems with Dial-in connections. Everything is ok but the disconnect after about 1-7 minutes. According to the syslogs & traps the case is Lost Carrier. Sudden retains are initiated. I've checked the Earthing, the peak voltage to nol is 3-5 vpp.
Any Ideas on this, Any clues , Hints to check.
Thanks in advance.
Hakopian
05-01-2002 06:44 AM
Do the lines come in as Analog (POTS) or are they derived from a T carrier (Digital) and converted?
05-02-2002 05:07 AM
Yes they are Analog (NM16AM Module & POTS).
SNR is OK about 28-32.
Did you have such a case?
About every other call is disconnected from remote (Client Side, Lost Carrier).
Any suggestions.
Great appreciations.
05-02-2002 06:57 AM
If you're sure calls are being disconnected from remote client side, then I'd check the modem options. It may be a case of one of the control signals dropping. Are you using software Flow Control (Xon/Xoff) (bad) or hardware flow control? (RTS/CTS) (good) . Look at how RTS, CTS, CD, DTRetc. are optioned. You may want to nail up CTS, or ignore DTR etc.
05-02-2002 10:51 AM
The same modems work with other Rases well, No disconn.
The users are out of my reach. And the flow is hardware.
The case is, all of a sudden retrain is initiated on modems i think it's because of poor line qualities.
Do you know of any line quality checking techniques to ensure of that part?
Thanks.
05-02-2002 01:10 PM
Well, there is specialized Test Equipment to check Analog phone lines, but it's not cheap. Call the Phone Company and have THEM test the lines for you!
