Community Member
3500 and 3550 series Switch Utilization
As the "show process cpu" command doesn't give the "Total Switch Load" in 3500 Series switches.
I have to use "show controllers switch" command to find the Bandwidth Usage. Is there an SNMP OID that i can use for collecting this info remotely ?
Is the above observation also true for 3550 series switches ? OR Does "show process cpu" gives an indication of switch load for 3550 series switches ?
Other than the above procedures, what the is best method for finding Switch BW utilization for 3500\3550 series switches using SNMP ?
Regards \\ Naman
Community Member
Re: 3500 and 3550 series Switch Utilization
try the following.
The current bandwidth consumed. The measurement unit is
in megabits per second (1 , 000 , 000 bits/second).
This value gives a reasonable estimate of the amount of
traffic currently flowing through the switch.
It is calculated as follows:
Octets*8 + Frames*(96 + 64)
Measurement Interval * 1 , 000 , 000 * 2
Measurement Interval is the amount of time over which
the Octets and Frames were collected , in seconds.
Measurement Interval is always one second in current
Octets is the total number of octets transmitted
or received by all network interfaces , excluding
framing data but including FCS. This includes octets
in frames which were partially transmitted or
received (due to collisions , for example).
Frames is the total number of frames transmitted
or received by all network interfaces , including
frames with errors.
The number of frames is multiplied by 96 plus 64 in
order to estimate the delay between each frame for
Ethernet's IPG and preamble/SFD.
The '2' in the divisor makes this a forwarding bandwidth
counter. A frame received on one interface is typically
forwarded out another interface. In order to avoid double-
counting this frame's bandwidth , once on the receiving
interface and once on the transmitting interface , the
total bandwidth is divided by two.
Since multicast and broadcast frames can be sent to multiple
ports , the above is at best a lower bound.
Community Member
Thanx. This works great for 3500 series switches.
However doesn't work for 3550 series switches. Maybe for 3550 , the usual cputotal1min OID gives useful information (As it does for IOS routers) ?
Community Member
Both the 3500XL and the 3550 series of switches move packets in
hardware. You should *not* expect the CPU load to be in any way
related to the total number of packets (or bits) moved through the
Sorry, I don't know of any useful OID for the 3550.
