3500Xl GBIC slot LED status
Hello Cisco expert,
Recently we have implemented gigastack on 3 3500XL in a cascaded and redundant format. However the LED on the middle switch Gbic slot(not on gigastack Gbic) showing Amber color. I am not sure if there is anything wrong with this symptom , but teh switch seems working fine at this stage.
Please advise if this is normal when configured gigastack cascaded and redundant link.
Edmond
1 REPLY
Re: 3500Xl GBIC slot LED status
Per Product Overview:
Solid amber
Port is not forwarding. Port was disabled by management or an address violation or was blocked by Spanning Tree Protocol (STP).
Note After a port is reconfigured, the port LED can remain amber for up to 30 seconds as STP checks the switch for possible loops.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/35xlhig/35overvu.htm#1029196
Please rate helpful post.
147
