Webcast-Catalyst9k
3508XL switch works inermittently
hi,
this is very typical problem i have faced.
3508XL switch works fine for 15 mins or sometime 30 mins then some of gigabit port shows amber and some which r not connected to other switch shows green. Switch behaves abnormaly.
i have captured the booting sequence.
here it is-----
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version
12.0(5.2)XU, MAINTENANCE IN
TERIM SOFTWARE
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 17-Jul-00 18:29 by ayounes
I-base: 0x00301F3C
Initializing C3500XL flash...
flashfs[1]: 110 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 3612672
flashfs[1]: Bytes used: 2768384
flashfs[1]: Bytes a
flashfs[1]: flashfs fsck took 3
seconds.
flashfs[1]: Initialization complete.
...done Initializing C3500XL flash.
C3500XL POST: System Board Test: Passed
C3500XL POST: Daughter Card Test: Passed
C3500XL POST: CPU Buffer Test: Passed
C3500XL POST FAILURE: CPU Notify RAM Test: Failed
C3500XL POST FAILURE: Error with CPU Interface CPU
Notify RAM POST.
C3500XL POST FAILURE: CPU Interface Test: Failed
C3500XL POST FAILURE: Cannot test CPU Interface ASIC
due to failure of
C3500XL POST FAILURE: CPU Interface CPU Notify RAM
due to failure of
C3500XL POST FAILURE: Testing Switch Core: Failed
C3500XL POST FAILURE: Testing Buffer Table: Failed
C35Data Buffer Test: Failed
C3500XL POST FAILURE: Configuring Switch Parameters:
Failed
C3500XL POST FAILURE: Switch Core failing because of
CPU Interface Failure
C3500XL POST g because of CPU-Interface failure
C3500XL POST FAILURE: Cannot test Modules due to
now if i restart after some time , SOMETIME it boots normal and works for few mins and again same story.
regards,
1 REPLY
Re: 3508XL switch works inermittently
The switch fails POST test and needs to be replaced. I suggest that you open a TAC case to get it replaced
186
