3524s - How to add another VLAN for Management
Within our 3524 workgroup switches we noticed the inability to add another VLAN. Queston: Can we add another VLAN, i.e. VLAN 500, to be used for Management only, instead of using the VLAN 1?
Re: 3524s - How to add another VLAN for Management
You sure can. Use the keyword "management" under interface vlan 500. This will shut down interface vlan 1 and interface vlan 500 will be up/up
You can have only one management vlan, either vlan 500 or vlan 1.
In case of 3524, do the following
config t
3524 (config)# interface vlan 500
3524(config-if)#management
This will put the previous management vlan (that is vlan 1 by default) to shutdown state.
On your switch, issue the comand "show vtp status". If your switch is in client mode, you can't add VLANs, they must be learned from a VTP server elsewhere in your network. The output below is from one of my 3524s in client mode.
HOSTNAME#sh vtp status
VTP Version : 2
Configuration Revision : 53
Maximum VLANs supported locally : 254
Number of existing VLANs : 29
VTP Operating Mode : Client
VTP Domain Name : VTP1
VTP Pruning Mode : Enabled
VTP V2 Mode : Enabled
VTP Traps Generation : Disabled
MD5 digest : 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Thanks...the problem was more related to IOS Version. In older versions, i.e. 11.2(8) only one VLAN can be configured on this switch at a time. The switches with IOS version 12.x.wc.... are fine... Time to upgrade the legacy IOS and add the VLAN Management correctly. Thanks for all the timely input!!!
123
