3548 switch and 3662 router duplex mismatch-an easy question
Hi, I got the log as following:
%CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/0 (not half duplex), with router-1 FastEthernet0/26 (half duplex).
the router's f0/0 is full duplex and the switch's f0/26 is with default configuration (full duplex?), so will the cable be the factor to result in the above info?
Thanks for any help!
1 REPLY
Re: 3548 switch and 3662 router duplex mismatch-an easy question
Try setting the speed and duplex at each interface. The auto setting can cause troubles.
103
