3548 switch flash loading problem
i want to load flash file into 3548 switch and the 3548 is in following state:
how do i proceed with it.
switch: ?
? -- Present list of available commands
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
load_helper -- Load and initialize a helper image
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_param -- Set system parameters in flash
sleep -- Sleep a specified number of seconds
trap -- Cause a software breakpoint to occur
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
switch:
awating reply soon.
thanks
1 REPLY
Bronze
Re: 3548 switch flash loading problem
You can use the copy command to load a file onto flash. For example:
Switch# copy tftp://10.200.8.200/config.text flash:config2.text
Here is a link that explains this in more detail:
http://www.cisco.com/warp/public/473/10.html#2
262
