11-14-2001 04:51 PM - edited 03-01-2019 07:23 PM
How to active telnet session on 3548 switch. One one can help me.
11-14-2001 09:13 PM
you need to configure a vlan 1 interface (default management interface) with an IP address first
and they you use the following to congigure password for telnet.
check out this link from the documention of the product
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35xu/scg/kiinter.htm#xtocid414533
11-15-2001 09:15 AM
I'm using vlan 330 as management VLAN. In this case do I need to configure the IP address with VLAN 330?
11-15-2001 09:18 AM
yes. make sure the default gateway is correct as well. In order to make vlan330 as the management, you need issue the command "management" under that interface.
