3548XL problems with IPX uplinked to a 2950G
jlwomeld
I added 3 new 2950G's and have the bottom of stack going into the top of stack on the 3548, the problem I am having is with IPX cust having problems connecting to the tree, all the switch are in the same vlan.
lgijssel
Level 9
Level 9
Check that you have configured spantree portfast on all the client-links. PC's will not get their IPX network-adress if this is not configured.
Leo
but dont set portfast on the link going back to the top of the stack. That sounds like a loop that will need the STP working fast.
I have a full novell network with IPX running. I don't need to install portfast on my ports of my switches , I have several 4506,4503,2924,3524,2950 switches.
And I don't have multiple VLAN's. But multiple sites/subnets.
If you have problems with finding your tree on the client side has much to do with you NDS design. THIS should be as flat as possible.
I had one problem with a SUP II engine that was not working correctly on a set of ports 33-48 on a 4506 (X-4418RJ 48 10/100port blade). On those ports you had login problems (extremely slow, seeing multiple non-existing trees,...) Replacing the engine was the solution.
I only use portfast on ports where our guys image there pc's and servers.
