3550/3750 Management Interface
Situation
The previous configuration was using vlan 1 as the management vlan and it is now being changed to
vlan "Z".
When configuring vlan "Z" as the managment vlan for a 3750 or 3550 is it necessary to have a vlan 1 interface on the switch at all ?
config t
int vlan Z
ip add x.x.x.x Y.Y.Y.Y
no shut
no interface vlan 1
1 REPLY
Re: 3550/3750 Management Interface
This is the default interface and afaik, cannot be removed. Simply shutting it down will bring it out of operation. HTH.
101
