3550 connectivity problem
We have been using 3548XL switches until now, when we are about to deploy 3550 switches.
Using basically the same configuration as for the 3548XL we encountered the following problem : when the first stack (of four switches) was connected via a GBIC to the 3Com 9400 corebuilder everything worked fine. As the second stack was connected, contact with the rest of the network was lost from both switches. It was however possible to ping and telnet from one stack to the other (through the corebuilder). Removal of the GBIC connection from one of the stacks restored network connectivity for the other stack.
The switch config is as follows.
version 12.1
no service pad
service timestamps debug uptime
service timestamps log datetime
service password-encryption
service sequence-numbers
hostname KR14stack1-1
enable password 7 21235446587
ip subnet-zero
interface FastEthernet0/1
no ip address
duplex half
speed 10
no snmp trap link-status
no cdp enable
spanning-tree portfast
*** identical config for remaining ports ***
interface FastEthernet0/48
no ip address
duplex half
speed 10
no cdp enable
interface GigabitEthernet0/1
no ip address
load-interval 30
no cdp enable
interface GigabitEthernet0/2
no ip address
no cdp enable
interface Vlan1
ip address 140.32.222.127 255.255.240.0
no ip route-cache
ip default-gateway 140.32.222.1
ip classless
ip http server
no cdp run
snmp-server engineID local 800000090300000AB7356881
snmp-server community l8y38k RO
snmp-server host 140.32.205.60 public
line con 0
line vty 0 4
password 7 00231154514F
login
line vty 5 15
password 7 04654D071C11
login
end
Re: 3550 connectivity problem
Although the prolem description does not match exactly, my first impression is that this issue might be caused by a spanning tree issue.
How long did you wait before and between disconnecting the links?
Do you know which device is the root of the spanning tree?
Are the Cisco switches interconnected through a second link?
Have you checked the bridge forwarding tables on 3Com device?
As I am not an expert with 3Com, I cannot help you with that but it might pay off to check that the 3Com switch is the root of the spanning tree.
Looks like a spanning tree problem. If you have 2 link connected to a switch make sure one if forwarding and one is blocking.
93
