3550-emi 12g cable requirements
We just purchased the 3550-emi 12g (Cisco Catalyst 3550-12G Switch— 10 GBIC-based Gigabit Ethernet ports and 2 10/100/1000BaseT ports). We
want to connect 2 of these devices via the 1000Base T ports. I checked
the cable requirements and I just want to be sure that we can do that
using a standard cat5 crossover cable. If not, could you supply a url
for the cable requirements and wiring diagram.
Thanks.
Re: 3550-emi 12g cable requirements
You will have to cross the other pairs too. Normal croos will not work.
1-3
2-6
3-1
4-7
5-8
6-2
7-4
8-5
Check the following link...
http://www.wiring.com/industry_diy/pin-outs.htm
regards
Thanks for your help.
This is not correct. You can use x-over cables where only 1,2,3,6 us used. We're using it and it is according to doc. on cco. If there is other recommondations, please inform me.
Check the following link. Cisco too recommends four twisted-pair, crossover Category 5 cabling for 1000BaseT ports. Are you sure you are getting a speed of 1000Mbps?
http://cisco.com/en/US/products/hw/modules/ps872/prod_release_note09186a00800e38ac.html#xtocid1019419
regards
Yes, the links is 1000Mbps/full. See:
http://www.cisco.com/en/US/partner/products/hw/switches/ps646/products_installation_guide_chapter09186a008007d160.html
but I agree that four twisted-pair should be used. Could be working in our case since the switches is locaded next to each other.
Thanks for the information. I thought the normal cross over doesn't work. Sorry for the confusion.
regards
I'm also very sorry for the confusion. When you posted your info. about using 4 pair I had to check my cables and I'm using all 4 pairs. I tested with using only 2 pair and IT IS NOT WORKING either for 10, 100 or 1000. You are correct.
232
