jks
3550+EMI: routed port traffic not passed by switched port on same 3550?
[this has got to be a FAQ - sorry] A 3550 running EMI is configured with a combination of routed ports and switched ports. A L3 device is plugged into the routed port. Routed traffic flows fine. When the routed port and the L3 device are instead plugged into the switched ports of the *same 3550* the traffic doesn't flow. If a different 3550 is used for the switched ports traffic flows fine as you would expect. What could possibly prevent the switched ports from doing their job? The MAC tables all looked fine. I tried using a seperate vlan for the switched ports. Is it just impossible to connect a routed port to a switched port on the same switch?
1 REPLY
jks
Re: 3550+EMI: routed port traffic not passed by switched port on
Oops: didn't quite understand that you could give a vlan an IP address. This solves my problem without using up two switch ports!
184
