04-11-2002 02:35 AM - edited 03-01-2019 09:15 PM
Help !
I have two 3550's interconnected by two gigabit links that are bound together. I also have two Vlans configured on both switches with a HSRP ip address. When the trunks are connected the switches complain about duplicate IP addresses on the LAN. It looks like a loop but the only connections between the boxes are the trunks.
Everything works fine with the trunks connected but the HSRP removed.
Has anyone seen this and is there a workaround ?
04-17-2002 12:55 PM
Often times complex troubleshooting issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, its often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
05-22-2002 01:04 PM
Did you set a priority for the standby interfaces. Example:
interface ethernet 0
ip address 10.1.1.2 255.255.255.0
mac-address 4000.0000.0010
standby 1 ip 10.1.1.1
standby 1 priority 200
I know I had a simular problem such as this and I fixed by setting a standby priority on both HSRP interfaces.
05-22-2002 02:06 PM
I sounds like you have a layer 2, due to the duplicate IP address messages. The MSFC will complain of duplicate IP address if it detects both routers as active at the same time or Layer 2 problem where the 3550 own packet gets reflected back.
Check out the following document for more details:
