3550 port problem
I have got 2 new cat 3550 switches.
I have got one at each building.I have it configured as a routed port on both switches.One port on each switch connected to a line of site laser.
The problem I am having is that the port is not picking up the laser.It shows as down down.
Both ports are configured as full duplex 100mb.
Even when I remove the routed hop configuration it still does not pick up the on the ports.
When I put in a 3com switch it seems to pick up the ports and it works.
Can soemone at Cisco please help understand why the switch is not picking up the laser units.It just shows down down with config or without.When I patch in anything else into the layer 3 switches it picks it up fine eg wireless radio and servers etc.
The IOS I am running is
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(13)EA1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 25-Mar-03 23:42 by yenanh
Image text-base: 0x00003000, data-base: 0x007C34B0
ROM: Bootstrap program is C3550 boot loader
NTQ3L01S01 uptime is 2 weeks, 21 hours, 12 minutes
System image file is "flash:c3550-i5q3l2-mz.121-13.EA1a/c3550-i5q3l2-mz.121-13.EA1a.bin"
cisco WS-C3550-24 (PowerPC) processor (revision J0) with 65526K/8192K bytes of memory.
Processor board ID CAT0730X0CF
Last reset from warm-reset
Bridging software.
Running Layer2/3 Switching Image
Any help would be much appreciated.
Re: 3550 port problem
Could you show the relevant interface configuration that you have on your switches and the show interface command.
Hi there
please see below for the configuration and show commands.Your help will be much appreciated.
building one
interface FastEthernet0/24
no switchport
ip address 10.99.8.2 255.255.255.252
duplex full
speed 100
building 2
description Laser Link to CI Tower
no switchport
ip address 10.99.8.1 255.255.255.252
duplex full
speed 100
NCITL02S03#sh interfaces fastEthernet 0/24
FastEthernet0/24 is down, line protocol is down (notconnect)
Hardware is Fast Ethernet, address is 000d.65db.6100 (bia 000d.65db.6100)
Description: Laser Link to TQ3
Internet address is 10.99.8.2/30
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicast)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
NTQ3L01S01>en
Password:
NTQ3L01S01#sho int fast
NTQ3L01S01#sho int fastEthernet 0/24
Hardware is Fast Ethernet, address is 000d.65d2.af00 (bia 000d.65d2.af00)
Description: Laser Link to CI Tower
Internet address is 10.99.8.1/30
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 251/255, txload 1/255, rxload 1/255
Last input 02:34:58, output 02:34:58, output hang never
24 packets input, 34751 bytes, 0 no buffer
Received 4 broadcasts (2 IP multicast)
28 input errors, 28 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 3 multicast, 0 pause input
2 packets output, 156 bytes, 0 underruns
Don't you need a "no shutdown" command on each interface?
The no shut commaand is already applied.
It would not say down down if it was shut.
It would say admintratively down down....
Bronze
Are you using a straight through or cross over cable from the switch to the laser?
I wonder if configuring no switchport changes the cabling requirements so that port is now an uplink port?
I think its crossover,but I have removed the no switchport command and it still dows not work.
mmmmmmm
Still cant find the problem.
What's the LED status of the port. If its not glowing, it could be a problem with the cable. Try changing the cable that you are using. Also try making the duplex and speed as auto.
I have tried all these things before already.
When I put in a 3com switch it comes up no probs.
When i put the cisco 3550 switches in it does not come up.Tried different ports as well.These 3550
are brand new and it picks up all other devices.
I am starting to think that there is some sort of incompatibility with the Laser units and the cisco 3550.
If anyone from cisco knows of any incompatibility between laser line of site unites and cisco switches
your help or guidance would be much appreciated.
From my reading 'no switchport' configures the port layer 3.
http://www.cisco.com/en/US/customer/products/hw/switches/ps646/products_configuration_guide_chapter09186a008014f345.html#1020563
Maybe the 3Com auto-detects if the port is normal or uplink. Suggest you try different cables ie. if using a crossover cable, try straight through cable.
Peter
If you try the laser in a port which is configured as a switchport, does it come up?
If so try creating a seperate vlan at each end of the link i.e. vlan 10.
Then on the interface at each end:-
no ip address
switchport mode access
switchport access vlan 10
no shut
Next create an interface vlan 10:-
int vlan 10
ip address x.x.x.x
See if this works.
I have downgraded the IOS on the 3550 from
c3550-i5q3l2-mz.121-14.EA1.bin to c3550-i5q3l2-mz.121-11.EA1.bin.
Since I did that the port connecting to the laser has come up.There must be a bug in the latest IOS which does not bring port up when connecting laser line of site units.Not sure....
Now that it is up up on both sides m y routed hop is not working.I cant ping the other sides port.
My radio link has the same config on the samew switch with different ip addresses and I can ping the other side no probs,but with the Laser units I cant ping the other side even though the port is up.
Really weird.Is this another bug or am i doing something wrong.I basically want eigrp to pick up the 2 links ie the radio and laser and let it pick the best successor which is the laser because the metric is better and let the radio be the feasible successor....Any help would be appreciated.
description Laser Link to TQ3
no switchport
duplex full
speed 100
no switchport
duplex full
speed 100
Anyone at Cisco seen this before?
problem resolved.
The Laser engineers had crimped the cable incorrectly and there was a fault on the interface card on the wireless.But it does not work with 12.1.14. It works with 12.1.11 on the 3550.
175
