3550 PWR Switch Stack Problem
Have a set of four 3550 PWR switches stacked together using gigastack mods.Uplinks are Gigabit Ethernet modes in switch one and three. For some
reason a gigastack module in one of the switches will shut itself down (interface is administratively down). Doing no shut or rebooting switch works for awhile then it goes down again. Is this a hardware, ie. switch or gigastack mod defect or could misconfiguration cause the same problem. There are several vlans configured on the switches.
DJE
  • Other Network Infrastructure Subjects
Bronze
Re: 3550 PWR Switch Stack Problem
Use the following link to see whether its the problem with the hardware or configuration.
If possible send the error message which you receive and the version of firmware which is loaded in the switch .
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800a2cac.shtml#subtopic2C
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a0080125913.shtml#trouble_gigabit
Thanks for the reply, I'll check those links. In the mean time I checked the output of show tech support. The interface in question had 752 Symbol error frames and 677 Invalid frames, too small. Also 46 Collision fragments Any idea what these might indicate ?
89
