Webcast-Catalyst9k
3550 Switch -Fiber interface VLAN question
I will deploying two Cisco 3550 Switches and connecting them via a ordinary multimode fiber with GBIC 1000BASE-SX - transceivers installed on each switch. Here is my question: I will be configureing about half of the ports on each of the switches to be in one of two VLANS. I would like to configure the two vlans to run over the single fiber line. Is is possible to configure one fiber port, with the GBIC 1000BASE-SX - transceiver installed, with two vlans and/or subinterfaces each with half of the 1000mb of bandwidth, or will I need to run an additional fiber line connected to the second fiber interface on the 3550 to accomplish this. I really hope not to as I don't have the funds to run a second line at this time. If this configuration is possible could someone please point me to documentation on how to configure this and\or give some advice. Thank you.
JPS
1 ACCEPTED SOLUTION
Purple
Re: 3550 Switch -Fiber interface VLAN question
Just set up the link as a trunk , this allows you to send as many vlans across that link as you want . On each side just do the following.
switchport
switchport trunk mode dynamic desirable
Verify trunk status with the "show int trunk " command.
More info at http://www.cisco.com/en/US/products/hw/switches/ps5528/products_configuration_guide_chapter09186a00803a9af5.html#wp1200245
Purple
switchport
Thank you. This is exactly what I was looking for.
JPS
275
