Community Member
3550 switches - STP or HSRP ?
My network consist of the following components :
- 4 3550-48 switches where all workstations reside on.
- GBIC links between the 4 switches (daisy-chained)
- GBIC link to 2 other switches where my servers reside.
- Servers all use 2 NIC's wich are teamed to provide fault tolerance.
The workstations are in a different ip-segment than the servers, so both of the switches uplinked to the switches where the servers reside must be able to route traffic fault-tolerant.
Reading all of the documentation, i understand i need to be able to use STP or HSRP on these 2 switches to be able to create fault-tolerance to the 2 other switches...
To be able to use STP, i need to configure a VLAN on the switches.
To be able to configure this vlan i understand i need to stack the switches so they will be able to understand that the vlan exists on both switches and routes to the same ip-segment.
To "stack" the 4 switches i am able to purchase 4 GigaStack modules, but will i be able to "stack" the switches together to address and configure them as 1 device ?
see attached file for network schematic
1 REPLY
Community Member
Re: 3550 switches - STP or HSRP ?
Yes, you can configure STP or HSRP for the scenario mentioned. Check the following link for more information on configuring HSRP :
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00801cdea2.html
and configuring STP :
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00801cdee4.html
100
