03-30-2006 09:13 AM - edited 03-03-2019 02:34 AM
I purchased a CAB-SFP-50CM Catalyst Interconnect Cable to connect two 3560s. When the cable is plugged in, I receive the following error in the Cisco Network Assistant:
Description: Gi0/1: This port has been disabled because Non Compliant Gigabit Interface Converter (GBIC) connector detected.
Recomendation: Replace connector with cisco compliant Gigabit Interface Converter (GBIC) connector. Refer switch technical documentation to determine cisco compliant connector. Enable the port again.
Any help? I assumed this would be a "plug and play" installation. Re-enabling the disabled port doesn't seem to help.
Thanks in advance...
03-30-2006 09:14 AM
You need a cisco branded gbic in order to work and yes they do cost quite a bit more.
03-30-2006 09:38 AM
Thanks for the response - this is a Cisco branded cable:
Manufacturer: CISCO
Description: CATALYST 3560 SFP INTERCONNECT CBL 50CM
Part Number: CAB-SFP-50CM=
I thought I had done my research...according to the 3560 data sheet
(http://www.cisco.com/en/US/products/hw/switches/ps5528/products_data_sheet09186a00801f3d7d.html)
"These ports also support the Cisco Catalyst 3560 SFP Interconnect Cable for establishing a low-cost Gigabit Ethernet point-to-point connection."
However, it doesn't seem to work. Is it possible that I've got a defective cable, or is there something else that I need to do?
Thanks again.
Edited to add: the cable I have is pictured in the data sheet (Figure 2) and the switches I am trying to interconnect are model WS-C3560-48PS.
03-30-2006 09:44 AM
Hi Jeffrey,
what version of IOS are you running? You may not be running the minimum IOS...
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps5012/prod_bulletin0900aecd80245121.html
HTH,
Bobby
03-30-2006 09:54 AM
Bobby - show version returns:
Switch Ports Model SW Version SW Image
* 1 52 WS-C3560-48PS 12.1(19)EA1d C3560-I9-M
I didn't have access to the article (I'm waiting for the "upgrade" to my account to be processed now)...can you tell me what the minimum IOS version is?
Thanks for the quick replies...I was expecting to wait days for an answer. (New here)
- Jeff
03-30-2006 10:01 AM
Hi Jeff,
Minimum is 12.2(25)SEA.
try this version of the same doc, you should have access to this one:
http://www.cisco.com/en/US/customer/products/sw/iosswrel/ps5012/prod_bulletin0900aecd80245121.html
HTH,
Bobby
*Please rate helpful posts
03-30-2006 10:10 AM
Bobby -
Thanks for the help. Although I still couldn't get access to the document through the second version, I will see what I can do to proceed in upgrading the IOS software.
- Jeff
