3560 monitoring
Hi all, I have just installed a 3560 switch, when I http into it, there is some monitoring tolls and traffic graphs etc, for some reason its not showing anything up on them ? any ideas why this is happening ?
1 REPLY
Re: 3560 monitoring
Hi Carl,
It could be due to 2 reasons :
1. Browser settings, check your browser settings.
2. Corrupted HTML files on the flash. Try to download the new IOS files with .tar extension and extract them and it should work for your.
I would suggest to use CNA (cisco network assistant) a free to use GUI tool for network management. You can download it from www.cisco.com/go/cna
HTH, Please rate if it does.
-amit singh
104
