04-12-2006 02:27 PM - edited 03-03-2019 02:47 AM
Hope you can help me here I'm having some issues with a router setup (I believe).
Config summary:
A 3560 router connect from port 0/1 to pcn, port 0/2 is connected to a netscreen 208 firewall with a dmz and an outside connection. The firewall was configured and testing before adding in the router switch and worked fine.
Testing:
- 3560 enhanced (I've attached a config file)
- can ping from the pcn to the outside interface on the router (192.168.3.1)
- cannot ping from the pcn to the firewall trusted port (192.168.3.2)
- can ping from the dmz to the outside port of the router (192.168.3.1)
- cannot ping from the dmz to inside port of the router (107.143.4.111)
- can ping from the router console to devices on the dmz
- can ping from the router console to devices on the pcn
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname RTGSW_01
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
--More-- vlan internal allocation policy ascending
interface GigabitEthernet0/1
no switchport
ip address 107.143.4.111 255.255.248.0
duplex full
interface GigabitEthernet0/2
no switchport
ip address 192.168.3.1 255.255.255.0
no ip redirects
no ip proxy-arp
duplex full
speed 100
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
--More-- !
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
--More-- interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
--More-- no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.3.2
no ip http server
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
end
RTGSW_01#
04-12-2006 03:00 PM
What subnet is the DMZ in? what vlan? Who/what is the default gateway for the DMZ? Can you extended ping from 3560 sourcing from the 107.143.4.111 to the DMZ? Same question for pcn.
04-12-2006 03:25 PM
The DMZ is on 192.168.2.0 subnet, gateway is 192.168.2.1/24. Can ping from the switch console port to the DMZ, cannot ping from the pcn (107.143.0.0/21 to the DMZ, infact I can't even ping to the firewall interface (192.168.3.2).
04-12-2006 03:33 PM
...a recap,
the pcn connects to the 0/1 interface
the firewall connects to the 0/2 interface
can ping from inside the dmz to the 0/2 interface on the router
cannot ping from inside the dmz to the 0/1 interface on the router
can ping from inside the pcn to the 0/1 interface on the router
cannot ping from inside the pcn to the 0/2 interface on the router
can ping from the router console to systems on the dmz and systems on the pcn
04-12-2006 07:17 PM
Canyou ping from the firewal to the ip address if gig 0/1 of the 3750? If not, I would check the firewall's routing configuration. It must know how to get to 107.143.0.0/21.
