Webcast-Catalyst9k
3560 routing problems
Hope you can help me here…I'm having some issues with a router setup (I believe).
Config summary:
A 3560 router connect from port 0/1 to pcn, port 0/2 is connected to a netscreen 208 firewall with a dmz and an outside connection. The firewall was configured and testing before adding in the router switch and worked fine.
Testing:
- 3560 enhanced (I've attached a config file)
- can ping from the pcn to the outside interface on the router (192.168.3.1)
- cannot ping from the pcn to the firewall trusted port (192.168.3.2)
- can ping from the dmz to the outside port of the router (192.168.3.1)
- cannot ping from the dmz to inside port of the router (107.143.4.111)
- can ping from the router console to devices on the dmz
- can ping from the router console to devices on the pcn
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname RTGSW_01
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
--More-- vlan internal allocation policy ascending
interface GigabitEthernet0/1
no switchport
ip address 107.143.4.111 255.255.248.0
duplex full
interface GigabitEthernet0/2
no switchport
ip address 192.168.3.1 255.255.255.0
no ip redirects
no ip proxy-arp
duplex full
speed 100
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
--More-- !
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
--More-- interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
--More-- no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.3.2
no ip http server
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
end
RTGSW_01#
Re: 3560 routing problems
What subnet is the DMZ in? what vlan? Who/what is the default gateway for the DMZ? Can you extended ping from 3560 sourcing from the 107.143.4.111 to the DMZ? Same question for pcn.
The DMZ is on 192.168.2.0 subnet, gateway is 192.168.2.1/24. Can ping from the switch console port to the DMZ, cannot ping from the pcn (107.143.0.0/21 to the DMZ, infact I can't even ping to the firewall interface (192.168.3.2).
...a recap,
the pcn connects to the 0/1 interface
the firewall connects to the 0/2 interface
can ping from inside the dmz to the 0/2 interface on the router
cannot ping from inside the dmz to the 0/1 interface on the router
can ping from inside the pcn to the 0/1 interface on the router
cannot ping from inside the pcn to the 0/2 interface on the router
can ping from the router console to systems on the dmz and systems on the pcn
Canyou ping from the firewal to the ip address if gig 0/1 of the 3750? If not, I would check the firewall's routing configuration. It must know how to get to 107.143.0.0/21.
119
