3560 Static Routing Problem - MOST URGENT- Please help
Hi All,
I have got a 3560 SMI Switch.
However whenever I configure Static Routes on switch and try finding the same by the command sh ip route static, I never see an entry.
Is it that switch is having some issue or its normal behavior?
Looking forward from all of you to rescue.
Kind Regards,
Wilson Samuel
1 REPLY
Blue
Re: 3560 Static Routing Problem - MOST URGENT- Please help
please post some config or at least show ip route output.
is ip routing enabled? is this SMI version capable of ip routing?
if your device is capable of ip routing and it is enabled and you put in a valid static route, then yes, you should see that route in the showIProute output.
100
