02-18-2004 07:03 PM - edited 03-02-2019 01:41 PM
I am having an issue with a 3620 Router with 2 Ethernet ports. I am trying to implement the ip firewall feature set. Current version of the IOS is 12.1 with Ip firewall feature set. I can telnet to the router and within the router can ping an internet address but the clients on the internal network can get to the internet. I have tired several different configurations of the access list right not I have it fully open as follows access-lsit permit ip any any on both sides to try to help diagnosis problem. I followed a configuration example from the following stie:
Am I missing something? Any ideas and/or suggestions? Here is a copy of current config:
Current configuration : 1387 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname xxxxxx
enable password 7 xxxxxxxxxxxxx!
ip subnet-zero
ip name-server 151.164.169.201
ip inspect max-incomplete high 1100
ip inspect one-minute high 1100
ip inspect name Ethernet_1_0 ftp
ip inspect name spgfw cuseeme timeout 3600
ip inspect name spgfw ftp timeout 3600
ip inspect name spgfw http timeout 3600
ip inspect name spgfw rcmd timeout 3600
ip inspect name spgfw realaudio timeout 3600
ip inspect name spgfw smtp timeout 3600
ip inspect name spgfw tftp timeout 30
ip inspect name spgfw udp timeout 15
ip inspect name spgfw tcp timeout 3600
ip audit po max-events 100
interface Ethernet1/0
description internal network
ip address 192.168.2.254 255.255.255.0
ip access-group 101 in
no ip route-cache
no ip mroute-cache
no cdp enable
interface Ethernet1/1
description connection to internet
ip address 192.168.10.230 255.255.255.0
ip access-group 111 in
no ip route-cache
no ip mroute-cache
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.10.253
no ip http server
access-list 101 permit ip any any
access-list 111 permit ip any any
snmp-server community public RO
line con 0
exec-timeout 0 0
login
line aux 0
line vty 0 4
login
end
THANKS
02-19-2004 05:19 AM
What is the ip address of the default gateway for your PCs? It should be pointing to the ip address 192.168.2.254.
Good luck,
Joe
02-19-2004 06:28 AM
The default gateway of all computers is 192.168.2.254
