3640 and NM-16ESW and routing
Can someone please point me in the right direction for the docs to configure this thing. I am looking at purchasing a 3640 router and the NM-16ESW 16 port switch module. I am hoping that I can use each port on a separate network and route between them with the routing part of the 3640. I haven't been able to find the link to actually configure the routing part. Do you use sub interfaces, etc?
I have no problem reading, I just want to make sure I am buying the correct pieces.
Don Hickey
  • Other Network Infrastructure Subjects
Re: 3640 and NM-16ESW and routing
Here is the place at which you will find the config guidelines for 16 port SW module
http://lbj.cisco.com/push_targets1/ucdit/cc/td/doc/product/software/ios122/122newft/122limit/122x/122xt/122xt_2/ft1636nm.htm
I actually had someone close to my location that had a 2600 and this switch module. He brought it over this morning to test and it does work. I was able to route and also NAT on the interfaces....
Pretty nice!
Don
Hi;
I tried the link and it did not work - could you give me a differnet link?
139
