eso
3640 connect e1 r2 problem HELP HELP HELP
boot system flash c3640-i-mz.122-6a.bin
logging buffered 8192 debugging
username test password 0 test
clock timezone MO 8
modem call-record terse
ip subnet-zero
no ip domain-lookup
chat-script offhook "" "ATH1" OK
chat-script callback ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT \T" TIMEOUT 30 CONNECT \c
modemcap entry PW2620:MSC=&F&D2S52=1S54=26
modemcap entry mica_v90:MSC=&F&D2
modemcap entry mica_k56flex:MSC=&F&D2S29=5
modemcap entry mica_v34:MSC=&F&D2S29=0
controller E1 1/0
framing NO-CRC4
ds0-group 1 timeslots 1-12 type r2-digital r2-compelled
cas-custom 1
unused-abcd 0 0 0 0
country uruguay
debounce-time 16
release-guard-time 500
seizure-ack-time 30
interface Loopback0
ip address x.x.x.x 255.255.255.240
no ip mroute-cache
interface Group-Async1
ip unnumbered Loopback0
encapsulation ppp
no ip mroute-cache
async mode interactive
peer default ip address pool dialin_pool
ppp authentication pap
group-range 97 108
ip local pool dialin_pool x.X.x.163 x.x.x.174
ip classless
ip pim bidir-enable
logging trap errors
access-list 199 permit tcp any any eq telnet log
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
line con 0
exec-timeout 0 0
line 97 108
modem answer-timeout 120
modem Dialin
modem autoconfigure discovery
transport input all
autoselect during-login
autoselect ppp
flowcontrol hardware
line aux 0
line vty 0 4
access-class 199 in
password xxxxxxx
login
When I dial to the number, the router didn't answer me phone. I see some message
*Apr 12 22:56:37.838: %CALLRECORD-3-MICA_TERSE_CALL_FAILED_REC: DS0 slot/contr/c
han=1/0/9, slot/port=3/10, call_id=16, calling=(n/a), called=(n/a), time=0, finl
-state=CALL_SETUP, disc(modem)=7F00 Condition occurred during call setup/Request
ed by host/non-specific host disconnect
debug modem
Modem control/process activation debugging is on
*Apr 12 22:59:15.780: Modem 3/11 Mica: configured for Answer mode, with Lower R2
signaling, 0x0 tone detection.
*Apr 12 22:59:15.896: Modem 3/11 Mica: in modem state CALL_SETUP
*Apr 12 22:59:41.739: Modem 3/11 Mica: dialing number '#'
*Apr 12 22:59:41.783: Modem 3/11 Mica: in modem state TERMINATING
*Apr 12 22:59:41.787: Modem 3/11 Mica: in modem state IDLE
*Apr 12 22:59:41.803: Modem 3/11 Mica: NAK'd command 0x129, while in modem state
IDLE
*Apr 12 22:59:41.803: Modem 3/11 Mica: DISCONNECT after 00:00:00, due to reason
(0x7F00) Host Disconnect.
*Apr 12 22:59:41.803: %CALLRECORD-3-MICA_TERSE_CALL_FAILED_REC: DS0 slot/contr/c
han=1/0/8, slot/port=3/11, call_id=17, calling=(n/a), called=(n/a), time=0, finl
*Apr 12 22:59:41.811: Modem 3/11 Mica: in modem state TERMINATING
*Apr 12 22:59:41.827: Modem 3/11 Mica: in modem state IDLE
Can anyone help ?
128
