Please help. I cannot get IMA group up.
This is result of sh ima int
Interface ATM2/IMA1 is down
Group index is 1
failure status is blockedNe
Active links bitmap 0x0
IMA Group Current Configuration:
Tx/Rx configured links bitmap 0x1E/0x1E
Tx/Rx minimum required links 1/1
Maximum allowed diff delay is 25ms, Tx frame length 128
Ne Tx clock mode ITC
Test pattern procedure is disabled
IMA Group Current Counters (time elapsed 0 seconds):
-1 Ne Failures, 1629593548 Fe Failures, 0 Unavail Secs
IMA Group Total Counters (last 0 15 minute intervals):
IMA link Information:
Link Physical Status NearEnd Rx Status Test Status
ATM2/1 down notInGroup disabled
ATM2/2 down notInGroup disabled
ATM2/3 down notInGroup disabled
ATM2/4 down notInGroup disabled
- if i delete IMA group then member fhisical interfaces are up
- in logs ther is
IMA reset group ATM2/IMA1
IMA: IMA interface is still waiting for a free channel.
every 10 minutes. I do not have live PVC channels in that group. Is this a problem maybe. Shouldnt't IMA group be up withoput any PVC
Thanks a lot
