3640 hardware/software problem
I have a 3640 fastethernet problem, the interface always appeared to be disabled, when I enter 'no shutdown' at the interface configuration mode, it can not work. Below is some of the command display result I entered. Hope someone can help me to resolve this problem.
Router#sh diag
Slot 0:
Sync/Async Port adapter, 8 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.0 Board revision E0
Serial number 13847436 Part number 800-01225-02
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 25 01 00 00 D3 4B 8C 50 04 C9 02 00 00 00 00
0x30: 70 09 E6 00 99 04 16 17 FF FF FF FF FF FF FF FF
Slot 1:
Mueslix-4T Port adapter, 4 ports
Hardware revision 1.1 Board revision D0
Serial number 13856996 Part number 800-02314-02
0x20: 01 54 01 01 00 D3 70 E4 50 09 0A 02 00 00 00 00
0x30: 68 00 00 00 99 04 20 00 00 05 FF FF FF FF FF FF
Slot 2:
Serial number 13856978 Part number 800-02314-02
0x20: 01 54 01 01 00 D3 70 D2 50 09 0A 02 00 00 00 00
Slot 3:
Fast-ethernet Port adapter, 1 port
Port adapter is disabled
Hardware revision 1.0 Board revision D0
Serial number 14220615 Part number 800-03490-02
0x20: 01 44 01 00 00 D8 FD 47 50 0D A2 02 00 00 00 00
0x30: 68 00 00 00 99 04 28 00 FF FF FF FF FF FF FF FF
Router#sh ver
IOS (tm) 3600 Software (C3640-I-M), Version 12.1(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Tue 16-May-00 12:26 by ccai
Image text-base: 0x600088F0, data-base: 0x60924000
ROM: System Bootstrap, Version 11.1(20)AA1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Router uptime is 11 minutes
System returned to ROM by reload
System image file is "flash:c3640-i-mz.121-2.T"
cisco 3640 (R4700) processor (revision 0x00) with 61440K/4096K bytes of memory.
Processor board ID 13893034
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
8 Serial network interface(s)
8 Low-speed serial(sync/async) network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Router#sh int f3/0
FastEthernet3/0 is administratively down, line protocol is down
Hardware is AmdFE, address is 00d0.5864.ba70 (bia 00d0.5864.ba70)
Internet address is 192.168.0.249/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Unknown duplex, Unknown Speed, 100BaseTX/FX
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
0 packets input, 0 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#int f3/0
Router(config-if)#no shutdown
Router(config-if)#end
Router#sh int f3/0
0 watchdog
If you have any others want to know ,please feel free to contact me at zhijunguo@vip.sina.com.
Thank you!
Guozhijun
Bronze
Re: 3640 hardware/software problem
My first suggestion would be to reboot the router but I see you already tried that.
Have you tried turning off the router, pulling the module out and putting it back in, then starting the router?
Could you try swapping the module with one in another slot?
regards,
Herbert
Silver
the ios is not recognizing the card in the sh ver it shows 8 serials and 8 low speeds no FE's . check the compatability matrix to see if the feature set you are running suppports this card
http://www.cisco.com/cgi-bin/front.x/Support/HWSWmatrix/hwswmatrix.cgi
By seeing the show diag output, it appears that the Port adapter is disabled.
Try enabling it or replace with otherone which is in good condition so that u can isolate the problem
-Deepu
I have solved the problem via re-seat the network module, thank everyone for your help!
guozhijun
136
