05-09-2002 12:59 AM - edited 03-01-2019 09:40 PM
Dear Sirs:
A new 3640 router with a NM-2FE2w and a NM-16AM, IOS Cisco Version 12.0(13), can not find the NM-2FE2W in show run, what can I do next? Thank you.
Some Information followed:
Router#show version
IOS (tm) 3600 Software (C3640-I-M), Version 12.0(13), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Tue 05-Sep-00 22:55 by linda
Image text-base: 0x60008918, data-base: 0x60684000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (f
c1)
Router uptime is 5 minutes
System restarted by power-on
System image file is "flash:c3640-i-mz.120-13"
cisco 3640 (R4700) processor (revision 0x00) with 24576K/8192K bytes of memory.
Processor board ID 26878039
R4700 processor, Implementation 33, Revision 1.0
Bridging software.
X.25 software, Version 3.0.0.
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
C3600 processor with 32768 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
program load complete, entry point: 0x80008000, size: 0x39074c
Self decompressing the image : #################################################
# [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Bridging software.
Press RETURN to get started!
00:00:03: %PA-2-UNDEFPA: Undefined Port Adaptor type 216 in bay 0
00:00:03: %LINK-4-NOMAC: A random default MAC address of 0000.0c83.8039 has
been chosen. Ensure that this address is unique, or specify MAC
addresses for commands (such as 'novell routing') that allow the
use of this address as a default.
00:00:05: %SYS-5-RESTART: System restarted --
Router>
Router>
Router>
05-09-2002 03:07 AM
hi
the minimum supported ios for the nm-2fe2w is 12.1 so you will need to upgrade your router, also more memory is needed i think. if you go to the TAC part of cisco's website there is a memory calculator on it use this and it will also tell you what ios and memory requirements you will need.
hope this helps
05-09-2002 06:07 AM
Thank you very much. Thanks Thanks Thanks
05-09-2002 03:20 AM
I am looking for in my documentation and I think that this modules
( NM-2FE2w ) in not suported for the cisco 3640.
It is suported for 3620 or Serie 2600.
The other module is suported in 3640.
Sorry
Bye
05-09-2002 03:56 AM
this module is supported, you can check on the cisco web site but it is supported
05-09-2002 04:03 AM
Sorry, It 's true, My documentation is old
Sorry ;-)
