3640 router console problem
I want to configure 3640 router that we have in the lab.but some reason i can not console into it. Nothing comes up in hyper terminal.I checked all the setting of my hyper terminal and it looks ok. My other 3640/3550 router/switch console works. Is there anyway to reset 3640 router.
Silver
Re: 3640 router console problem
You are most likely connected ox the setting in your hyperterm does not match what the console speed is set for , have you tried different speeds in your hyperterm ?
What is your config reg set for ?
It seems to be hardware problem but it can be repaired.
87
