3640 won't respond to gns requests over isdn dialup
async interface will respond but isdn will not, details below.
Async62 is up, line protocol is up
(IPX network number cloned from interface Loopback0)
IPX address is 48500011.0009.b7fe.1b40 [up]
Delay of this IPX network, in ticks is 30 throughput 0 link delay 0
IPXWAN processing not enabled on this interface.
IPX SAP updates are never sent
IPX type 20 propagation packet forwarding is disabled
Incoming access list is not set
Outgoing access list is not set
IPX helper access list is not set
SAP GGS output filter list is not set
SAP GNS processing enabled, delay 0 ms, output filter list is not set
SAP Input filter list is not set
SAP Output filter list is not set
SAP Router filter list is not set
Netbios Input host access list is not set
Netbios Input bytes access list is not set
Netbios Output host access list is not set
Netbios Output bytes access list is not set
Updates are never sent aging multiples RIP: 3 SAP: 3
SAP interpacket delay is 55 ms, maximum size is 480 bytes
RIP interpacket delay is 55 ms, maximum size is 432 bytes
RIP response delay is not set
Watchdog processing is currently disabled
SPX spoofing is disabled, idle time 60
IPX accounting is disabled
IPX fast switching is configured (enabled)
RIP packets received 29, RIP packets sent 29, 0 Throttled
RIP specific requests received 29, RIP specific replies sent 29
RIP general requests received 0, 0 ignored, RIP general replies sent 0
SAP packets received 2, SAP packets sent 2, 0 Throttled
SAP GNS packets received 2, SAP GNS replies sent 2
SAP GGS packets received 0, 0 ignored, SAP GGS replies sent 0
Dialer1 is up, line protocol is up
(IPX network number cloned from interface Loopback1)
IPX address is 48500021.0009.b7fe.1b40 [up]
Delay of this IPX network, in ticks is 6 throughput 0 link delay 0
IPX fast switching is not configured
RIP packets received 1749, RIP packets sent 1109, 0 Throttled
RIP specific requests received 1749, RIP specific replies sent 1749
SAP packets received 260, SAP packets sent 2065, 0 Throttled
SAP GNS packets received 132, SAP GNS replies sent 0
SAP GGS packets received 117, 0 ignored, SAP GGS replies sent 879
Re: 3640 won't respond to gns requests over isdn dialup
You could try the following document which has information about Troubleshooting IPX problems.
http://www.cisco.com/warp/customer/473/33.html
This problem seems to be related to similar bugs associated with IPX connectivity over dial-up. You can use the Bug Toolkit tool to get more information about following bugs :
CSCdk26170
CSCdm62598
thanks for that but have already solved problem, for info i took the ipx network off the loopback interface which was mapped to dialer1 with the ipx ppp-client command and applied it directly to the dialer interface and it all seems to work fine now.
thanks
mark
97
