3662 startup problem
it seems that it's the flash has some problem.Or the memory?
rommon 2 > reset
System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
C3660 processor with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
program load complete, entry point: 0x80008000, size: 0x4c1f90
Self decompressing the image : #
Error : Uncompression of the image failed.
invalid compressed data--format violated
Error : zip decompress failed
*** System received a Software forced crash ***
signal= 0x17, code= 0x7, context= 0x0
PC = 0x800080d4, Cause = 0x20, Status Reg = 0x3041f003
PCMCIA Slot1: No Card Present
rommon 1 >
rommon 1 >
rommon 1 >
  • Other Network Infrastructure Subjects
Re: 3662 startup problem
try to reload IOS image into the Flash memory, if problem is repeated, report this to Cisco as You have hardware problem with Your router
Giedrius
Silver
try to load an image on a pcmcia card and try to boot to the image on this card.
> boot slot0:image name
Also 3660 come in 2 models a service provider and an enterprise make sure the image you are trying to load is for the correct type of chassis.
219
