3745 and IPXCP Problems
Hello All,
I was hoping one you you could help me with the following problem.
I have just configured a 3745 with a NM30DM and E1/PRI for accepting incoming async dialup users.
IP is working fine for dialup users, works a treat. However, I cannot say the same for IPX. When I dialin (Windows XP) I get an "Error 773"
Here's a "debug ppp negotiation" from the 3745:
03:40:22: As52 PPP: Phase is UP
03:40:22: As52 IPCP: O CONFREQ [Closed] id 1 len 10
03:40:22: As52 IPCP: Address 10.27.66.1 (0x03060A1B4201)
03:40:22: As52 IPXCP: I CONFREQ [Not negotiated] id 5 len 18
03:40:22: As52 IPXCP: Network 0x00000000 (0x010600000000)
03:40:22: As52 IPXCP: Node 02ee.0ef0.bdc7 (0x020802EE0EF0BDC7)
03:40:22: As52 LCP: O PROTREJ [Open] id 202 len 24 protocol IPXCP
03:40:22: As52 LCP: (0x802B01050012010600000000020802EE)
03:40:22: As52 LCP: (0x0EF0BDC7)
03:40:22: As52 CCP: I CONFREQ [Not negotiated] id 6 len 10
03:40:22: As52 CCP: MS-PPC supported bits 0x00000001 (0x120600000001)
03:40:22: As52 LCP: O PROTREJ [Open] id 203 len 16 protocol CCP (0x80FD0106000A120600000001)
And here's a snapshot of the 3745 config:
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname CISCO-RAS1
aaa new-model
aaa authentication login default group radius
aaa authentication ppp default if-needed group radius
aaa session-id common
enable secret yadayadayada
ip subnet-zero
no ip domain-lookup
ipx routing 0009.7ce3.a050
isdn switch-type primary-net5
fax interface-type fax-mail
mta receive maximum-recipients 0
controller E1 2/0
framing CRC4 Australia
pri-group timeslots 1-31
interface Loopback0
ip address 10.27.66.1 255.255.255.0
interface FastEthernet0/0
ip address 10.27.88.1 255.255.255.0
duplex full
speed 100
ipx network 102788D
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial2/0:15
no ip address
encapsulation ppp
isdn incoming-voice modem
no cdp enable
interface Group-Async1
ip unnumbered Loopback0
encapsulation ppp
dialer in-band
dialer-group 1
async mode dedicated
ipx network 102766D
peer default ip address pool dialin
ppp authentication pap chap
group-range 33 62
ip local pool dialin 10.27.66.100 10.27.66.200
ip classless
ip route 0.0.0.0 0.0.0.0 10.27.88.254
no ip http server
ip pim bidir-enable
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
radius-server host 10.27.1.1 auth-port 1645 acct-port 1646 key cisco
radius-server retransmit 3
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line 33 62
modem InOut
line aux 0
line vty 0 4
password cisco
end
Any help would be greatly appreciated.
1 REPLY
Bronze
Re: 3745 and IPXCP Problems
Hi Paul,
I'm not an IPX expert, but is the fifth line of the debug output indicating that the user is dialing in with a network number of 0? If so, this does not match the network number of 102766D on the Group-Async interface, and these will have to match in order to have a successful connection. Of course, this change will have to be made on the client. Unfortunately, Cisco's documentation has very little on configuring dial access with anything other than IP.
Please feel free to correct me.
Good luck.
Mark
109
