3750 and RMON
l.heigl
Which RMON Agent License for Catalyst 3750 must I order?
Is it available?
Thanks and regards
gmarogi
Level 5
Level 5
If you are talking about the RMON groups, I heard only Alarms and Events are supported on the 3750. You can check with the Feature navigator tool, if you have a CCO account.
That's not what I mean.
You can choice between three versions.
Catalyst 3xxx Agent License
WS-C3000-EMS-LIC Catalyst 3000 RMON Agent License
WS-C3100-EMS-LIC Catalyst 3100 RMON Agent License
WS-C3200-EMS-LIC Catalyst 3200 RMON Agent License
or maybe "WS-C3750-EMS-LIC Catalyst 3750 RMON Agent License" for future ????
There are no infos in pricelist from june.
