3750 port setting options
We would like to configure the settings on a copper port on a 3750 to 10MB half duplex.
My only options for duplex are full or auto.
Also under speed options I do not have an option for non-negotiate.
running 12.1.11 code (it does need to be upgraded).
Would an upgrade resolve this?
Re: 3750 port setting options
I have just looked on one of ours and I am able to configure speed 10 duplex half
sncore01#sh run int g1/0/20
Building configuration...
Current configuration : 62 bytes
interface GigabitEthernet1/0/20
speed 10
duplex half
end
I am running the following image, so perhaps an upgrade may eradicate the issue.
Hello together,
I have customer with C3750 and copper SFP too.
our customer have 12.2(25)SEC2 and a 10Mbit/FD connection to his provider. The link to the GigaEthernet interface of the c3750 have input errors/CRC errors.
when I connected a c2611 with a ethernet interface and FD no errors occur. Have you simelar experience with this behavior?
best regards
michael rittner
Purple
You should always hardcode the speed before trying to do the duplex , this may be your problem .
the switch port is configured so:
interface GigabitEthernet1/0/8
no switchport
ip vrf forwarding aopn
ip address 161.90.179.254 255.255.255.128
ip access-group acl_AOPN_in in
ip access-group acl_AOPN_out out
no ip redirects
no ip unreachables
no ip proxy-arp
rate-limit output access-group 120 512000 96000 128000 conform-action transmit exceed-action drop
duplex full
speed 10
Interface Status:
GigabitEthernet1/0/8 is up, line protocol is up
Hardware is Gigabit Ethernet, address is 000f.90ca.1dcf (bia 000f.90ca.1dcf)
Internet address is 161.90.179.254/25
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 252/255, txload 1/255, rxload 1/255
Keepalive not set
Full-duplex, 10Mb/s, media type is 10/100/1000BaseTX SFP
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
46642 packets input, 46008074 bytes, 0 no buffer
Received 2883 broadcasts (0 IP multicast)
1405 input errors, 1405 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 2103 multicast, 0 pause input
44229 packets output, 36589331 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
With the router 2611 no errors happen:
router interface:
interface Ethernet0/1
ip access-group level0_f0/0 in
ip access-group 100 out
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting output-packets
full-duplex
no cdp enable
best regards
michael rittner
Purple
Did you try setting it at half duplex ? Seems to me on some of the older 2600 series even though the option was there to set it at full duplex it didn't really work and was only running half duplex , could be wrong though .
no, but I will ask the customer whether he can do this.
best regards
michael
330
