3845 gbic and hwic port configuration
I have just added 2 gbics and 2 hwics 1gig interfaces to the 3845 router and i have noticed that there isnt a speed and duplex command for those interfaces though the internal gig ports have them. Is it a diff command to force the speed/duplex on those interfaces?
Pete
1 REPLY
VIP Purple
Re: 3845 gbic and hwic port configuration
Hello Pete,
the HWICs only supports 1000 Mbps in full duplex. "Speed" or "duplex" commands are not supported under the interface.
Check this link to the relevant Q&A (scroll down to the bottom of the page, the last Q&A under the ´Features´ section is what you are looking for:
Cisco Gigabit Ethernet High-Speed WAN Interface Card
http://www.cisco.com/en/US/products/ps5949/products_qanda_item0900aecd80169bf0.shtml
HTH,
GP
474
