4003(old) and 4506 vrrp problem!
hi,everyone,
I have a old 4003 with one 34-port layer router card and a 4506, they are configured with vrrp, but all the 4003's port-channel1.X always change from standby to active,and then change to stanby, so when I ping it always lose the packets.
And the other question is the 4003's 34-ports module,whose g1 and g2 are configured with trunk, there are many flapping presenting, but when I diable the trunking on the g1 and g2,but the 4003's vlan is not available.
the configuration is below:
4003:
***** NON-DEFAULT CONFIGURATION *****
#time: Wed Sep 17 2003, 18:42:18
#version 5.5(13a)
#system web interface version(s)
#frame distribution method
set port channel all distribution mac both
#vtp
set vtp domain Tiens
set vtp mode client
#ip
set interface sl0 down
set interface me1 down
#syslog
set logging level cops 2 default
#set boot command
set boot config-register 0x2
set boot system flash bootflash:cat4000.5-5-13a.bin
set boot system flash bootflash:cat4000.5-1-1.bin
set boot system flash bootflash:cat4000.5-4-2.bin
#port channel
set port channel 3/1-2 45
set port channel 3/3-4 87
#module 1 : 0-port Switching Supervisor
#module 2 : 6-port 1000BaseX Ethernet
set trunk 2/1 on dot1q 1-1005
set trunk 2/2 on dot1q 1-1005
#module 3 : 34-port Router Switch Card
set vlan 200 3/3
set vlan 202 3/5
set vlan 210 3/13,3/34
set trunk 3/1 off dot1q 1-1005
set trunk 3/2 off dot1q 1-1005
set port channel 3/1-2 mode on
end
there is problem:
2003 Sep 17 18:42:47 %SYS-4-P2_WARN: 1/Tag 8 on packet from 00:00:0c:07:ac:08 port 3/2, but port's native vlan is 1
4003 router:
Cat4003>en
Password:
Cat4003#sh run
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Cat4003
enable password 7 1511021F0725
ip subnet-zero
no ip domain-lookup
interface Port-channel1
no ip address
no ip directed-broadcast
hold-queue 300 in
interface Port-channel1.1
encapsulation dot1Q 1 native
ip address 9.0.102.102 255.255.0.0
no ip redirects
standby 1 priority 90
standby 1 preempt
standby 1 ip 9.0.0.254
interface Port-channel1.2
encapsulation dot1Q 2
ip address 10.1.2.241 255.255.255.0
ip helper-address 10.1.2.1
no ip redirects
standby 2 priority 90
standby 2 preempt
standby 2 ip 10.1.2.254
interface Port-channel1.3
encapsulation dot1Q 3
ip address 10.1.3.241 255.255.255.0
no ip redirects
standby 3 priority 90
standby 3 preempt
standby 3 ip 10.1.3.254
interface Port-channel1.4
encapsulation dot1Q 4
ip address 10.1.4.241 255.255.255.0
no ip redirects
standby 4 priority 90
standby 4 preempt
standby 4 ip 10.1.4.254
interface Port-channel1.5
encapsulation dot1Q 5
ip address 10.1.5.241 255.255.255.0
no ip redirects
standby 5 priority 90
standby 5 preempt
standby 5 ip 10.1.5.254
interface Port-channel1.6
encapsulation dot1Q 6
ip address 10.1.6.241 255.255.255.0
no ip redirects
standby 6 priority 90
standby 6 preempt
standby 6 ip 10.1.6.254
interface Port-channel1.7
encapsulation dot1Q 7
ip address 10.1.7.241 255.255.255.0
no ip redirects
standby 7 priority 90
standby 7 preempt
standby 7 ip 10.1.7.254
interface Port-channel1.8
encapsulation dot1Q 8
ip address 10.1.8.241 255.255.255.0
no ip redirects
standby 8 priority 90
standby 8 preempt
standby 8 ip 10.1.8.254
interface Port-channel1.9
encapsulation dot1Q 9
ip address 10.1.9.241 255.255.255.0
no ip redirects
standby 9 priority 90
standby 9 preempt
standby 9 ip 10.1.9.254
interface Port-channel1.10
encapsulation dot1Q 10
ip address 10.1.10.241 255.255.255.0
--More-- 2003 Sep 17 18:43:48 %SYS-4-P2_WARN: 1/Tag 23 on packet from 00:00:0c:07:ac:17 port 3/1, but port's native vlan is 1
no ip redirects
standby 10 priority 90
standby 10 preempt
standby 10 ip 10.1.10.254
interface Port-channel1.11
encapsulation dot1Q 11
ip address 10.1.11.241 255.255.255.0
no ip redirects
standby 11 priority 90
standby 11 preempt
standby 11 ip 10.1.11.254
interface Port-channel1.12
encapsulation dot1Q 12
ip address 10.1.12.241 255.255.255.0
no ip redirects
standby 12 priority 90
standby 12 preempt
standby 12 ip 10.1.12.254
interface Port-channel1.33
encapsulation dot1Q 33
ip address 10.1.33.241 255.255.255.0
no ip redirects
standby 33 priority 90
standby 33 preempt
standby 33 ip 10.1.33.254
interface Port-channel1.34
encapsulation dot1Q 34
ip address 10.1.34.241 255.255.255.0
no ip redirects
standby 34 priority 90
standby 34 preempt
standby 34 ip 10.1.34.254
interface Port-channel1.35
encapsulation dot1Q 35
ip address 10.1.35.241 255.255.255.0
no ip redirects
standby 35 priority 90
standby 35 preempt
standby 35 ip 10.1.35.254
interface Port-channel1.200
encapsulation dot1Q 200
ip address 10.1.200.241 255.255.255.0
no ip redirects
standby 200 priority 90
standby 200 preempt
standby 200 ip 10.1.200.254
interface Port-channel1.202
encapsulation dot1Q 202
ip address 10.1.202.241 255.255.255.0
no ip redirects
standby 202 priority 90
standby 202 preempt
interface Port-channel1.210
encapsulation dot1Q 210
ip address 10.1.210.241 255.255.255.0
no ip redirects
standby 210 priority 90
standby 210 preempt
standby 210 ip 10.1.210.254
interface Port-channel2
no ip address
hold-queue 300 in
interface FastEthernet1
no ip address
shutdown
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
shutdown
interface GigabitEthernet3
no ip address
no negotiation auto
channel-group 1
interface GigabitEthernet4
no ip address
no negotiation auto
channel-group 1
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.200.253
arp 10.1.200.253 0150.5a01.c8fd ARPA
arp 127.0.0.2 0005.5eb8.1600 ARPA
line con 0
transport input none
line aux 0
line vty 0 4
password 7 02050D480809
login
end
1 REPLY
Re: 4003(old) and 4506 vrrp problem!
I hope this helps. The 2 GBICs G1 and G2 are Routed interfaces. The rest 32 Ports are only Layer 2. It is a bit confusing exactly what you want but I think this info might help some. Also you are on the right track with the G3 and G4 this is your connection to the backplane. Here is a link for more info:
http://www.cisco.com/warp/public/473/28.html
Corey
229
