4003 Supervisory Engine Compatibility
Hi all,
I just want to know if the 4003 CAT is only to be used with a SUP I blade. From what I read on documentation I don't think it's compatible with the SUP II , much less the SUP III for that matter. Any clarification would be greatly appreciated.
Re: 4003 Supervisory Engine Compatibility
You are correct, 4003 only works with SupI. 4006 will work with SupII or SupIII.
I am configuring a 4006 RSM. Do you know of any REALLY GOOD documentation on setting up the 2 internal GIG channels along with whether or not I should port channel and/or trunk on those 2 backplane channels? I have to configure OSPF on this rsm and give it a static route to my corporate router which is a 3com product. I know that if I choose th trunk than the 3com link must know about the new VLAN subnet as well as ecapsulate using dot1Q. Correct ????
Thanks, I'll look into it.
88
