Webcast-Catalyst9k
4006 CAT OS Command help
I have got a 4006 Supervisor Engine 2 and a Gigabit module - WS-X4148-RJ45V 48 port 10/100/1000Base-T Gigabit Ethernet and another 10/100 module - WS-X4448-GB-RJ45 48 port inline 10/100Base-TX ports
Since its is using CAT OS and Im not familiar with CAT OS, I would really like some help on CAT OS command to do the following:
1. Set-up the switch just to do normal switching - no fancy stuff like, VLAN etc
2. Set up the GIG/10/100 ports to be on Etherchannel
Hope someone helps
1 REPLY
Bronze
Re: 4006 CAT OS Command help
Start out by reading the catalyst 4000 quick start guide.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/rel7_1/quick_sw/index.htm
80
