Webcast-Catalyst9k
v.j
4006 L3 module.
How to configure the L3 module for inter vlan routing.How the two physical gbic port can be used.
How the switch can be configured to communicate with the router(L3)module.Any website address or any config? Thanks.
Re: 4006 L3 module.
The below URL lists all the FAQs and sample configs for lan technologies
http://www.cisco.com/warp/public/473/
and your specific question is available at
http://www.cisco.com/warp/public/473/28.html
v.j
Re: 4006 L3 module.
How should we configre the external gbic ports on the L3 module as an uplink to the vlan in a 3524 switch.
Re: 4006 L3 module.
It's going to take a little reading, and checking out the sample configs. You should read up on things with the links that bsivasub provided.
The short story is to make the L3 vlan interfaces to match the VLANs in the 3524 (assuming you configure a VTP domain that both subscribe to). Once you do that, assign both switchs' GBIC ports to the desired VLAN, hook them up, and then configure your L3 module just as you would if the 3524 switch wasn't there.
If that doesn't make sense, it *reading time*!!
120
