Community Member
4006 vs 2950 and the art of PXE Boot. Help!!!
WS-C4006 Software, Version NmpSW: 6.3(5)
Supr engine II
4 48 port 10/100 blades.
All on vlan 1.
VTP ver 2
V2 mode enabled.
cgmp enabled.
Tried to get an XP workstation to boot from PXE server.
Server ip 10.18.7.250
DCHP pool 10.18.7.100-160
Ip gateway 10.18.1.250
Subnet for all 255.255.248.0
Cannot get the workstation to boot.
Place both connections into a 2950 out of the box with no config done to
it and the pc will boot from the PXE server.
What did I miss on the 4006
Let me know any addition info needed.
BW
Community Member
Re: 4006 vs 2950 and the art of PXE Boot. Help!!!
We had this same problem and found that you must issue the command: "set port host " on all the access ports that you have these XP stations attached to.
Craig.
Community Member
Craig
Thank you very much for the quick response.
Worked like a charm!!!!!!!!!!!
Thanks again!!
Bob
178
