Community Member
4006 with supervisor II using SPAN function
Here is my config on supervisor II
Console> (enable) show span
Destination : Port 4/10
Admin Source : VLAN 2
Oper Source : Port 2/3,2/5-6
Direction : transmit/receive
Incoming Packets: enabled
Learning : enabled
Filter : -
Status : active
Total local span sessions: 1
Is it correct ??
I try to connect IDS 4235 with 4.0 version on port 4/10 to monitor VLAN2
when I try to use a TCP-RESET action on IDS
It does not work , why ??
1 REPLY
Bronze
Re: 4006 with supervisor II using SPAN function
IDS can send TCP-resets through SPAN ports, better check your config
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat5000/rel_6_2/_config/span.htm
82
