4506 and Wireless AP 1200's
e-pategas
Can the 4506 supply power to both radio's A&B in the AP 1200? (11 watts)
DO the ports in the WS-4148-RJ45V supply more than 6.3 watts because the AP 1200 with both radios A&B require 11 watts?
If the 4506 cannot supply 11 watts, does this mean a Power Injector must be used with the AP 1200 for both radios?
thisisshanky
Level 11
Level 11
Did you opt to choose a power transformer (AC) which comes usually along with the AP 1200, or you opted for a power injector. Power injector is needed for Power over Ethernet connections while using in conjuction with the AP1200, with 802.11 a and dual radio 802.11a/802.11b configurations.
For 802.11b only configurations, you can use the inline power switch module you have.
Remember if you have to get a power injector, you have to pay from your pocket extra. while the power transformer that comes with AP1200 is shipped free along with the unit.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
kenjohnson
Definitely requires a power transformer or injector for dual A/B operation - though with 802.11af support in future blades that should be a non-issue. But you'll have to wait until they are available.
Ken Johnson
LeTourneau University
CIPTUG
Cisco IP Telephony Users Group
http://www.ciptug.org
